  • maverrick 8 posts 20 karma points
    Jan 23, 2009 @ 11:28
    maverrick
    [help] - what to do next after install???
    dear all,
    i've just start interested in umbraco and have just installed it on my machine. (i choose runway (basic feature))
    after login i got stuck!!. there are 4 button. create, about, help, and log out --" the only button that work is help and log out.
    then where should i do next??? please help T.T
    Jan 23, 2009 @ 11:44
    Dirk De Grave
    Hi maverrick,
    Here's a link with a bunch of useful links to toturials and interesting articles.
    http://www.nibble.be/?p=40
    Regards,
    /Dirk
  • Lesley 284 posts 143 karma points
    Jan 23, 2009 @ 13:09
    Lesley
    [quote=maverrick] there are 4 button. create, about, help, and log out --" the only button that work is help and log out.
    [/quote]
    So that's all you see? There's nothing at all below those buttons?
    The screen should look something like this (with a Content tree and Sections buttons...)
    ... Then it sounds like something odd has happened in your install process. Please confirm and then we'll try to get to the bottom of the problem.
    Lesley
    Jan 23, 2009 @ 15:24
    maverrick
    wow how's that screen comes up? i can only see those 4 button on the top. everything else is blank white --"
    i'm using umbraco v4.0
    having
    win xp pro
    iis enabled
    not using any virtual directories
    my computer connected to domain domain controller
    installed all the prerequisites (including VS 2005 and VS 2008)
    4 of my other collages also having the same problem.
    i thought it was because i choose basic feature, i delete everything and start all over. then the routine just getting back again. lost of errors occur again, from invalid object umbracouser to everything with permission denied even though i've grant the aspnet full permission. i'm going nuts with this. HELP!!
    Jan 23, 2009 @ 18:19
    Lesley
    Okay then. Strange that it should go wrong after an apparently successful install, but let's try a few things...
    1. Do you get the Runway (Boost) homepage if you go to http://localhost?
    2. Have all the files extracted correctly? In addition to default.aspx and web.config, you should have the following folders in your root:
    appcode, bin, config, css, data, install, masterpages, media, python, scripts, umbraco, umbracoclient, usercontrols, xslt
    3. Have you set the ASPNET account permission on the root folder or just the ones listed in the setup instructions? Just curious here. I like to set it on the root, but make sure permissions are propegating down. Have a look at a file in /umbraco/images/, say... does ASPNET have permission on that?
    Interesting that your colleagues have the same problem. Have they each run the install on their machines or are they accessing yours?
  • crazy123321 2 posts 20 karma points
    Jan 24, 2009 @ 20:58
    crazy123321
    I'm getting the same problem as maverrick and I've had enough, I've wasted too much time on this. This CMS is totally unimpressive, lacks proper support at every level, and has a ridiculous and very problematic installation process.
  • jaygreasley 416 posts 403 karma points
    Jan 24, 2009 @ 21:24
    jaygreasley
    When you granted aspnet full permissions did you set it to reapply the rights to all subdirectories?
    Jan 27, 2009 @ 04:30
    maverrick
    [quote=Lezzles]Okay then. Strange that it should go wrong after an apparently successful install, but let's try a few things...
    yes
    yes
    yes i even apply it on my wwwroot folder
    no they're usin their own machine, some of them even had only trace page
    [/quote]
    i've downloaded the rc 4 version, my looks like my computer is acting strange, with aspnet_wp.exe it keeps showing dont send dialog
    Jan 27, 2009 @ 14:19
    maverrick
    ok finally.
    i've format my computer and reinstall everything and downloaded umbraco 4 RC 3 and it works fine. i think this last version is stable.
